17 years agoabout Spansion flash
Hi, I use Spansion flash S29GL256N on Stratix II GX audio-video development board. I checked the datasheet and it should be OK to use the AMD29LV128M flash driver that is provied as Presets by...
17 years agoHi Jake,
I have a question about the .sdc file. Sentences like set_clock_latency -source -early 0.9 [get_clocks {eth_tx_clk}] set_clock_latency -source -late 1.2 [get_clocks {eth_tx_clk}] set_clock_latency -source -early 0.97 [get_clocks {eth_rx_clk}] set_clock_latency -source -late 1.3 [get_clocks {eth_rx_clk}]# Input delays set_input_delay -clock [get_clocks {clk_sopc}] 0.000 [get_ports {enet_mdio}] set_input_delay -clock [get_clocks {eth_rx_clk}] -max 10.40 [get_ports {enet_rx_col enet_rx_crs enet_rx_dv enet_rx_er enet_rxd*}] set_input_delay -clock [get_clocks {eth_rx_clk}] -min 10.90 [get_ports {enet_rx_col enet_rx_crs enet_rx_dv enet_rx_er enet_rxd*}] are they design-specific or can be used in general case?
