17 years agoabout Spansion flash
Hi, I use Spansion flash S29GL256N on Stratix II GX audio-video development board. I checked the datasheet and it should be OK to use the AMD29LV128M flash driver that is provied as Presets by...
17 years agoHi Jake,
If you get the time check the archived project which is pretty much the same as your reference design. Although there is timing warning the design works. But it seems that the eth_rx_clk, eth_tx_clk should be fine tuned concerning timing constraints if i want to use the opencore and add some other big logic blocks.
