17 years agoabout Spansion flash
Hi, I use Spansion flash S29GL256N on Stratix II GX audio-video development board. I checked the datasheet and it should be OK to use the AMD29LV128M flash driver that is provied as Presets by...
17 years agoHi Jake,
This is what i got in messages. Critical Warning: Timing requirements not met Info: Worst-case hold slack is -0.588 Info: Slack End Point TNS Clock Info: ========= ============= ===================== Info: -0.588 -0.588 eth_rx_clk Info: 0.041 0.000 eth_tx_clk Info: 0.341 0.000 clk_fpga Info: 0.341 0.000 clk_sopc Info: 0.341 0.000 io_clk Info: 5.421 0.000 ssram_clk_int Info: 9.500 0.000 n/a and i use your .sdc file for the timing setting.
