17 years agoabout Spansion flash
Hi, I use Spansion flash S29GL256N on Stratix II GX audio-video development board. I checked the datasheet and it should be OK to use the AMD29LV128M flash driver that is provied as Presets by...
17 years agoI can probably work you up a simple example design that you can just run but you'll have to bare with me as I can only work it in between other things. If I can't get it to you today then perhaps tomorrow.
Jake
