17 years agoabout Spansion flash
Hi, I use Spansion flash S29GL256N on Stratix II GX audio-video development board. I checked the datasheet and it should be OK to use the AMD29LV128M flash driver that is provied as Presets by...
17 years agoyeah that's strange ...
1 - Are your pin assignments all correct? These are what I show: set_location_assignment PIN_D13 -to enet_mdc set_location_assignment PIN_C13 -to enet_mdio It looks like you changed the names, did you also add pin assignments for the new names? 2 - Can you scope the mdc and mdio pins at the PHY to see if they are toggling? Jake
