17 years agoabout Spansion flash
Hi, I use Spansion flash S29GL256N on Stratix II GX audio-video development board. I checked the datasheet and it should be OK to use the AMD29LV128M flash driver that is provied as Presets by...
17 years agoHi Jake,
simply for test i used the TSE MAC in 10/100 Mhz small MAC mode. I removed the gmii_mii_mux module and modified my top level file. But still I got the error message that "ERROR : MAC Group[0] - No PHY connected!". I am really confused. Any response is appreciated. My top level file is: ------------------------------------------------------------------- module ddr2_test_top( enet_rx_dv, enet_rx_crs, enet_rx_col, enet_rx_clk, enet_tx_clk, enet_rx_er, pb_user_resetn, clk, enet_rxd, enet_tx_en, enet_tx_er, mdc, ddr2_cas_n, ddr2_rasn, ddr2_wen, mdio, ddr2_a, ddr2_ba, ddr2_cke, ddr2_clk_n, ddr2_clk_p, ddr2_csn, ddr2_dm, ddr2_dq, ddr2_dqs_p, ddr2_odt, enet_txd ); input enet_rx_dv; input enet_rx_crs; input enet_rx_col; input enet_rx_clk; input enet_tx_clk; input enet_rx_er; input pb_user_resetn; input clk; input [3:0] enet_rxd; output enet_tx_en; output enet_tx_er; output mdc; output ddr2_cas_n; output ddr2_rasn; output ddr2_wen; inout mdio; output [13:0] ddr2_a; output [1:0] ddr2_ba; output [0:0] ddr2_cke; inout [2:0] ddr2_clk_n; inout [2:0] ddr2_clk_p; output [0:0] ddr2_csn; output [0:0] ddr2_dm; inout [7:0] ddr2_dq; inout [0:0] ddr2_dqs_p; output [0:0] ddr2_odt; output [3:0] enet_txd; wire mdio_out; wire mdio_oen; assign wire_GND = 0; assign mdio = mdio_oen ? 1'bz : mdio_out; nios_ddr2 b2v_inst(.clk_to_tse_pll(clk), .clk(clk), .reset_n(pb_user_resetn), .global_reset_n_to_the_ddr_sdram_0(pb_user_resetn), .m_rx_col_to_the_tse_mac(enet_rx_col), .m_rx_crs_to_the_tse_mac(enet_rx_crs), .m_rx_d_to_the_tse_mac(enet_rxd), .m_rx_en_to_the_tse_mac(enet_rx_dv), .m_rx_err_to_the_tse_mac(enet_rx_er), .mdio_in_to_the_tse_mac(mdio), .rx_clk_to_the_tse_mac(enet_rx_clk), .tx_clk_to_the_tse_mac(enet_tx_clk), .mem_dqs_to_and_from_the_ddr_sdram_0(ddr2_dqs_p), .mem_clk_n_to_and_from_the_ddr_sdram_0(ddr2_clk_n), .mem_clk_to_and_from_the_ddr_sdram_0(ddr2_clk_p), .mem_dq_to_and_from_the_ddr_sdram_0(ddr2_dq), .mem_cas_n_from_the_ddr_sdram_0(ddr2_cas_n), .mem_cke_from_the_ddr_sdram_0(ddr2_cke), .mem_cs_n_from_the_ddr_sdram_0(ddr2_csn), .mem_dm_from_the_ddr_sdram_0(ddr2_dm), .mem_odt_from_the_ddr_sdram_0(ddr2_odt), .mem_ras_n_from_the_ddr_sdram_0(ddr2_rasn), .mem_we_n_from_the_ddr_sdram_0(ddr2_wen), .eth_mode_from_the_tse_mac(wire_GND), .m_tx_en_from_the_tse_mac(enet_tx_en), .m_tx_err_from_the_tse_mac(enet_tx_er), .mdc_from_the_tse_mac(mdc), .mdio_oen_from_the_tse_mac(mdio_oen), .mdio_out_from_the_tse_mac(mdio_out), .m_tx_d_from_the_tse_mac(enet_txd), .mem_addr_from_the_ddr_sdram_0(ddr2_a), .mem_ba_from_the_ddr_sdram_0(ddr2_ba)); endmodule ------------------------------------------------------------
