17 years agoabout Spansion flash
Hi, I use Spansion flash S29GL256N on Stratix II GX audio-video development board. I checked the datasheet and it should be OK to use the AMD29LV128M flash driver that is provied as Presets by...
17 years agoYes I have used the ethernet and it works without issue. Here is a modified "network_utilities.c" file that you can use in the Simple Socket Server example that just hard-codes the MAC address. You'll have to rename it from "network_utlities.c.txt".
Jake
