17 years agoabout Spansion flash
Hi, I use Spansion flash S29GL256N on Stratix II GX audio-video development board. I checked the datasheet and it should be OK to use the AMD29LV128M flash driver that is provied as Presets by...
17 years agoHi Jake,
thanks for the reply! :) In the shipped project for flash test the component spansion_512_0 is missing and i can not create the right new component using the shipped spansion_512.v file. I have created a new "service request" to Altera and i will keep you posted when i get the response from them. By the way, may i ask have you tested the ethernet function on this board? Since i can not get the flash work at this moment i got some problem when trying to modify the simple socket server example to test the ethernet function.
