TGao's avatar
TGao
6 years ago
A10 voltage conversion
Hi
BecauseA10 3.0 IO is not enough, can I use max10 for voltage conversion?
If Yes,How(3V-1.8V)? Thanks
Ted​
  • Rahul_S_Intel1's avatar
    Rahul_S_Intel1
    Hi Ted,
    If I understand your question correctly , you need have voltage IO standard conversion IC, I am recommending to use the voltage conversion IC, If you are using MAX 10 , IO standard have to set according to your design
  • TGao's avatar
    TGao
    HI Rsree,
    Noted it . Thanks!
    Ted
