TGao
6 years agoA10 schematic Check
Dear Sir/Madam, The attachment is A10 schematic, and I have something not sure, could you help check it? The board have two pcs FPGA, how connect them by using the JTAG and AS? Thanks Ted ...
JohnT_Altera
6 years agoHi,
The configuration pin looks fine to me. Since the JTAG pin is connected separately then it should be fine. No problem with the AS connection as well. Please make sure that the MSEL pin is set correctly.
If you have doubt on the JTAG and AS connection, you may always refer back to https://www.intel.com/content/www/us/en/programmable/documentation/sam1403483633377.html#sam1403482901661 Figure 137.
- TGao6 years ago
Hi Johnt, Noted it, Thanks for your help! Ted
