HungLam
6 years agoA10 GX DEV KIT - PCIE to control SPI core ( 3 wire) IP - Regmap
Hi, I am designing an application similar to PCIe to SPI bridge. I used PCIe HIP and SPI ( 3 wire) peripheral. My design used only bar0 and bar4, and I connect bar4 avmm to spi core avms, PCIe bar4...
HungLam
6 years agoHi,
It worked with nios, but now we would like to hook SPI core to PCIe memory map for direct command from host pc.
I figured out that the problem was with avmm addressing. I am trying to understand, since SPI core using 16 bits bus width, but AVMM from PCIe using 32 bits bus width ( or could be 256 bits bus width).
This caused the issue, I am trying to fix it.
Thanks for your answer!
Halotem12
6 years agoDid you manged to solve 3 wire spi core connection ?
