16 years ago88e1111 loopback
hai all, i'm using ml505 board. when i tried to put the ethernet phy (marvel 88e1111) in loopback mode, its not happening. the data i sent through tx lines is not coming through rx lines. i follow...
16 years agocan you please answer this simple question Marvel Alaska 88e1111 is software programmable? or hardware programmable only by changing low high states on its pin?
