17 years ago7-segment display via schematic
I'm trying to create a simple circuit, using 4 switches (8-4-2-1) to drive digital logic, in order to light a single 7-segment LED. I've created the 4 input pins, wired them to inputs A,B,C, an...
17 years agoThe posting isn't completely wrong here, I think. Basically the warnings idicate, that you have no logic connetion in effect between inputs and output, as you also see in the test. I guess that you used schematic entry with a maxplus2 library component. You either forgot to wire an enable signal of the 7447 component or didn't connect the in-and outputs correctly.
