16 years ago3.3 V Output needed from Cyclone III Starter Kit
Here is a simple question: q: how do i generate a 3.3 v level digital output from my cyclone iii starter kit ? i setup the following experiment: 1) I wrote a simple code to transfer a di...
16 years agoThank You very much fvm, for the quick response. You saved me from further headaches.
Now that I know that, 2.5V is the Starter-Kit standard ... a 3.3V-level input signal won't be that much of a problem (I've tested it) But for my output, which was supposed to go to a 3.3V-level DAC ... I'll need to check its compatibility with 2.5V-level. Or otherwise, as thangalt says ... search for a voltage translator IC. So long then.
