SDe_J
3 years ago25Gbps transceiver on stratix 10 h-tile
Hello Intel Forums, I have implemented a 25Gbps transceiver on a Stratix 10 h-tile devkit ( this one ). I am currently sending dummy data out on the TX side, which is looped back into the RX side. ...
ZiYing_Intel
3 years agoHi Sde_J,
Below are the possible root causes for the glitches:
1. signal integrity
2. signaltap sampling issue
3. potential timing problem at the RX parallel interface
Solution for each root cause of the glitches:
1. Use another cable
2. Try to increase the sampling clock frequency
3. Check the timing report
Zi YIng
