  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    This post is the same as https://forums.intel.com/s/question/0D50P00004bTNOT. May I know which post you want to use for communication?
    I compared the pin file for standard181 and pro191. The pin location are the same for both version. May I know what is the differences ? May I know what is pcg you are referring to?
    KhaiY
  • PYu2's avatar
    PYu2
    Hi KhaiY,
    谢谢回复,可能描述有问题,我想了解的是18.1standard 和18.1pro结果不一样?而不是18.1pro和19.1pro的结果不同。谢谢!​
    KhaiChein_Y_Intel
    I am sorry that I could not understand the question. I tried to google translate
    18.1standard 和18.1pro结果不一样 -> 18.1standard and 18.1pro have different results
    而不是18.1pro和19.1pro的结果不同 ->
    Instead of 18.1pro and 19.1pro the results are different
    I checked the pin file for standard181 and pro191. The pin location are the same for both versions.
    May I know what differences are you referring to? Could you give an example?
    KhaiY
