10M50DAF672I7G supports 1.0V IO Voltage or not
Tried with Quartus Prime Version 22.1 Std.
Error gone away but seeing a critical warning.
we are planning to use 4 Bank's of the FPGA, IO's expected to toggle at @100Mhz.
Any suggestions regarding this warning message.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin AD20 with surrounding 1.0 V I/O pins is 8.506000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin AE17 with surrounding 1.0 V I/O pins is 8.165000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin AD18 with surrounding 1.0 V I/O pins is 7.550000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin AC18 with surrounding 1.0 V I/O pins is 8.191000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin AE20 with surrounding 1.0 V I/O pins is 8.396000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin AE21 with surrounding 1.0 V I/O pins is 9.784000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin AB24 with surrounding 1.0 V I/O pins is 8.030000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin AF24 with surrounding 1.0 V I/O pins is 7.457000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin AF23 with surrounding 1.0 V I/O pins is 9.775000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin AF21 with surrounding 1.0 V I/O pins is 8.277000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin K25 with surrounding 1.0 V I/O pins is 8.480000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin J25 with surrounding 1.0 V I/O pins is 7.596000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin L26 with surrounding 1.0 V I/O pins is 8.160000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin N26 with surrounding 1.0 V I/O pins is 7.652000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin P26 with surrounding 1.0 V I/O pins is 9.638000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin P25 with surrounding 1.0 V I/O pins is 8.067000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin Y25 with surrounding 1.0 V I/O pins is 10.421000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin Y26 with surrounding 1.0 V I/O pins is 8.377000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin AC25 with surrounding 1.0 V I/O pins is 9.931000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
Critical Warning (21688): The total mutual inductance (Lm) of 1.0 V I/O pin AC24 with surrounding 1.0 V I/O pins is 9.728000 nH. This is not allowed. The total mutual inductance must be less than or equal to 7.41 nH.
- FvM3 years ago
mutual inductance spec for 1.0 V IO standard is explained in MAX10 General Purpose I/O User Guide. General suggestion to reduce total mutual inductance: leave unused pins in 1.0V bank.
