OLevy1
5 years ago10G-EPON
hi,
i am searching for a 10G-EPON MAC solution.
searching the IP Catalog i have found some kind of Eth MACs but none supporting 10GBASE-PR or 10GBASE-PRX (ieee 802.3av).
supposing there are non...
SengKok_L_Intel
5 years agoHi,
If this is targeting FPGA, you may refer to table 3 in the following link for the PHY that compliance with the Low Latency 10G MAC. And yes, the base PR is not listed there.
Assuming you are targetting Arria 10, by referring to the Arria 10 transceiver PHY IP user guide (section 2.6), there is no base PR either.
Please provide more info if further help is needed.
Regards -SK
OLevy1
5 years agothanks a lot,
does one of the Eth IP Cores (i am interested in Rx ONLY) can be used in case i will implement myself the PMA and PCS (all the way to XGMII)?
is there an IP Eth Core that can get as an input the XGMII (10Gbps) and output the Ethernet Packets on Avalon Streaming?
