LQian16
6 years ago目前调试10AS066高速收发器,FPGA连接光模块,光模块收发回环,现在测试发现低于7Gbps数据收发正常,但是高于7Gbps就不稳定,到9Gbps完全收不到数据,请问这种情况有可能是什么问题呢,有什么办法可以排查呢?硬件电路是参考开发板做的,电路设计应该没有问题。
1 Reply
- CheepinC_altera
Sorry for the delay. As I understand it, you are observing the loopback test with optical module seems unable to receive data correct at data rate >7Gbps. Lower than 7Gbps, there is no issue. This seems to be trending to signal integrity issue. To further narrow down, just wonder if you have had a chance to test enabling internal serial loopback and test at data rate >7Gbps to see if data can be received correctly. This would be helpful to narrow down to signal integrity issue.
Thank you.
