TGao
6 years ago在C10GX中的DDR3 IP avalon 位宽如何修改?
Hi 您好, 在C10GX中的DDR3 IP 设置中avalon 位宽如何修改? Ted
- 6 years ago
Hi Ted,
Thank you for the Quartus version confirmation.
The parameter is actually hidden in the Quartus. Under the "Controller" tab, you need to right click the EMIF GUI and click "Show Hidden Parameter" as shown below
Then just scroll down and you will be able to see the "Maximum avalon-mm burst length" setting as per highlighted in yellow.
Kindly let me know if you still unable to see it.
Aida
TGao
6 years agoHi Aida,
Thanks for your reply.
Yes, It;s DDR3L. and Maybe I describe not clearly, the width I mean is "Maxmun avalon-mm burst length" . This is easily changed in lpddr2 but I can't find in DDR3L .
Ted
