NZhan1
6 years ago加入SDC文件后编译报错
在用7.2版本进行时序约束的时候,写好的SDC文件在全局编译的情况下始终会报错;其报错内容为: 1,Critical Warning: Read_sdc failed due to errors in the SDC file 2,Error: wrong # args: should be source fileName while executing sou...
KhaiChein_Y_Intel
6 years agoHi,
This might be the reason. Since customer can compile the design after creating a new sdc, I suggest customer to continue using the new sdc. If customer faces any problem with the new sdc, please provide the design for investigation. I can help to compile in the latest version of the software and see if the problem persists.
KhaiY
