NZhan1
6 years ago加入SDC文件后编译报错
在用7.2版本进行时序约束的时候,写好的SDC文件在全局编译的情况下始终会报错;其报错内容为: 1,Critical Warning: Read_sdc failed due to errors in the SDC file 2,Error: wrong # args: should be source fileName while executing sou...
KhaiChein_Y_Intel
6 years agoHi,
Could you share both the working and non-working sdc file?
KhaiY
- NZhan16 years ago
Hi KhaiY, Pls check the attachment. Thanks! But for the same SDC working with the same Quartus project, it will be okay on version 7.1, but not version 7.2. Thanks! ************************************************** DISCLAIMER: This email is for the use of the intended recipient(s) only. If you have received this email in error, please notify the sender immediately and then delete it. If you are not the intended recipient, you must not keep, use, disclose, copy or distribute this email without the author’s prior permission. We have taken precautions to minimize the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses. The information contained in this communication may be confidential and may be subject to the attorney-client privilege. If you are the intended recipient and you do not wish to receive similar electronic messages from us in future then please respond to the sender to this effect. **************************************************
