AMa
6 years ago关于Arria 10 QDR IV的疑问
请教下~ Arria 10如果接QDR IV,最大位宽可以是多少?也就是最大可以接多少pcs(QDR颗粒36bit),接法是跟DDR3/4一样嘛? 另外~datasheet内说,可以支持到1066Mhz,这个是指的-1的器件 还是所有器件都可以支持到?
NurAida_A_Intel
6 years agoDear AMa,
Thank you for joining this Intel Community.
You may refer to EMIF spec estimator tools in link provided below . This tool allows you to find and compare the performance of the supported external memory interfaces in Intel® FPGAs. You’ll be able to filter down to specific features based on your targeted specifications . It also will show you what is the data width and speed grade supported based on the criteria you have chosen for analysis.
EMIF spec estimator --> https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/external-memory-interfaces-support/emif.html#
I sincerely hope this helps. 😊 Let me know if you have any question.
Aida
