Why does my cyclone V GX pcie fail to establish communication when the temperature is low?
Hi DAVID455912142,
Regarding the 7 pieces that needed to be powered on and work for 3-4 minutes to heat up, were they originally placed at room temperature?
Could you please check the following items?
1. Can the FPGA be configured using JTAG?
2. Can the flash be programmed using JTAG?
3. Can FPGA be loaded from flash using AS configuration - regardless of the temperature condition. Hot/Cold/Room
4. Can you see the CONF_DONE signal turned HIGH after the AS configuration? (flash uploaded its contents into FPGA).
5. Can you share whether the timing closure of the project has violation or not?
Ven
- DAVID4559121421 year ago
Hi ven
1. YES,I Can the FPGA be configured using JTAG!
2. YES,Can the flash be programmed using JTAG!
3.YES, FPGA be loaded from flash using AS configuration - regardless of the temperature condition!
4.I can see the CONF_DONE signal turned HIGH after the AS configuration.
5.Please refer to the attachment for compilation information.
6.Test record are some test records of hardware.
david
