HRZ
4 years agoHave you installed the SDK (which also installs the necessary drivers) and programmed the FPGA with a valid firmware to enable the PCI-E core? The following document covers all necessary steps:
https://cdrdv2.intel.com/v1/dl/getContent/709277?fileName=aocl_getting_started-683188-709277.pdf
- bear0054 years ago
thanks, after I read the link you provided, I see what is in the picture. Does this mean that I plugged the FPGA directly into the server, and the problem that the OpenCL platform cannot be detected is that I didn't find a technician to configure the environment?
- HRZ3 years ago
What is the exact model of the board you are using? If you are using a supported board which comes with an OpenCL BSP, you should be able to set it up yourself by following the documentation.
