Avinash1's avatar
Avinash1
4 years ago
Unable to compile the vector add usm program for any FPGA hardware
Hi ,
I was facing a few problems trying to compile and run my code on FPGA. I was unable to run the pre-compiled binary on FPGA as well. So I thought to try compiling the sample vector add usm for both arria and stratix, as I was unsure which one supported USM. I've attached images to show what I've tried and the resulting error.
Thank You
  • Avinash1's avatar
    Avinash1
    Thank you for the reply.
    I looked into the link provided and added the BSP flag for stratix usm. I was able to compile the sample but I am not able to run it on an FPGA. Below are the steps I followed while trying to compile and run the code. Could you let me know where I went wrong.
    1) created a compile_and_run.sh file with the following content
    #!/bin/bash
    source /opt/intel/inteloneapi/setvars.sh --force
    cd oneAPI-samples/DirectProgramming/DPC++/DenseLinearAlgebra/vector-add/src
    echo STARTING COMPILATION
    dpcpp -fintelfpga -Xshardware -Xsboard=/opt/intel/oneapi/intel_s10sx_pac:pac_s10_usm vector-add-usm.cpp -o vector_usm.fpga
    echo COMPILATION DONE
    echo STARTING TO RUN ON FPGA HARDWARE
    ./vector_usm.fpga
    echo RUN COMPLETE
    2) submitted the job to a node containing fpga_compile property (qsub -l node=1:fpga_compile:ppn=2 -d . compile_and_run.sh)
    3) The resulting output and error files were generated (screenshots attached)
    4) While I tried to run the stratix code on a node having 'fpga_compile' I could not run it. So I opened an Interactive session with a node having 'fpga-runtime' and 'stratix10' as properties and ran the code (./..../vector_usm.fpga). The following was the result :
    Running on device: Intel(R) FPGA Emulation Device
    Vector size: 10000
    An exception is caught while adding two vectors.
    terminate called after throwing an instance of 'cl::sycl::runtime_error'
    what(): Native API failed. Native API returns: -42 (CL_INVALID_BINARY) -42 (CL_INVALID_BINARY)
    Aborted
    For some reason it is not able to select the FPGA hardware. Is there a particular node having usm supported FPGA ?
  • Christoph9's avatar
    Christoph9
    Hey,
    first of: You ca not run the fpga-executables on the fpga_compile-nodes. It is therefore necessary to use the runtime-nodes (As you did in the later steps).
    On the stratix-node, you will probably need to initialize the board using the usm-bsp:
    aocl initialize acl0 pac_s10_usm
    Before this, sycl-ls could returns something like this:
    uxxxxx@s001-n142:~/$ sycl-ls
    [opencl:cpu:0] Intel(R) OpenCL, Intel(R) Xeon(R) Platinum 8256 CPU @ 3.80GHz 3.0 [2022.14.7.0.30_160000]
    [opencl:acc:1] Intel(R) FPGA SDK for OpenCL(TM), pac_s10 : Intel PAC Platform (pac_ee00000) 1.0 [2022.3]
    [host:host:0] SYCL host platform, SYCL host device 1.2 [1.2]
    After initializing it should return the following:
    [opencl:acc:1] Intel(R) FPGA SDK for OpenCL(TM), pac_s10_usm : Intel PAC Platform (pac_ee00000) 1.0 [2022.3]
    Hope this helps,
    Christoph
    • Avinash1's avatar
      Avinash1
      Hi Christoph,
      I followed your instructions and was able to initialize stratix-usm but still unable to run it. It gives the same error as mentioned before.
      Could you let me know if there are any flags that I might be missing during compilation ?
      This is the current command I use :
      I've kept the code for compilation again but I've changed the code to select an FPGA hardware or nothing unlike before where it selected an FPGA EMULATOR. I'd have to see if it works.
      Could you try compiling and executing the vector add sample code if possible ?
      Thank You,
      Avinash
  • hareesh's avatar
    hareesh
    i am working on it. pls give me some time. i'll get back to you.
  • hareesh's avatar
    hareesh
    any update?
    still do you facing that problem?
  • hareesh's avatar
    hareesh
