Typical way of loading runtime to Arm core (HPS)
Hi Kevin Xu,
By mentioning "You can usually get the ASP from your board vendor, or it can be generated by following this guide", does it mean I can skip generating BSP/ASP myself if I am able to get those support packages from, as you suggested, the board vendor?
Now the guidance on ofs.github.io seems pretty scary to me. I spent two days without figuring out where should I start with. Each step seems to have a bunch of prerequisits and assumptions. I think those steps might be too much before I can run a simple line of 'helloWorld' and become the first-day learner of oneAPI.
If I can somehow get the well-crafted BSP/ASP, does it mean I can start with something like 'aocl install <BSP_root_folder>'? That will make my life much easier. Thanks!
Best,
Runlong
Hi Runlong,
I can work on getting a BSP/ASP for the I-serial Devkit. But i want to mention:
- It's not going to work with the ARM host you mentioned, only with an x86 host.
- Even if we can generate a BSP/ASP that supports ARM core, the oneAPI runtime still won't work on ARM.
- If running with ARM is a hard requirement, the only way I can think of is to export your oneAPI design as an RTL IP, and connect it to the HPS ARM core in Quartus Platform Designer.
-Kevin
- uniqueMR2 years ago
Hi Kevin,
Thank you so much for your time and effort. Yes, using ARM host is NOT a strong requirements for me at this point. I mentioned the ARM core just because I related it to my other project experience in the past. In the end, I will follow what oneAPI workflow expects me to do. I really appreciate that you can help me with BSP/ASP for I-series Devkit.
Runlong
- Kevin_Xu_Intel2 years ago
Hi Runlong,
I was unable to local a pre-build BSP/ASP for the I-Series devkit. The best I can find is a pre build FIM for this devkit:
Go to https://github.com/OFS/ofs-agx7-pcie-attach/releases/tag/ofs-2024.1-1, and download iseries-1x400-images_ofs-2024-1-1.tar.gz
This FIM should allows you to skip section 2.2 entirely, and it is the most time consuming steps in the process of creating BSP/ASP.
Let me know if you need any help generating BSP/ASP.
-Kevin
Hi Kevin,
Thank you for providing the resources. I will try to generate BSP/ASP based on the FIM and let you know if there are other problems.
Runlong
