Stratix 10 PHY Lite Avalon bus waitrequest issue
Hi Sir,
Please accept my apology for the delay in response due to workload.
Can you please help to verify following ?
1. Ensure reset_n is toggle out of reset mode. From 0 to 1
2. Ensure correct clock frequency is supplied to DDR4 pll_refclk input pin. This will enable DDR4 PLL to operate and generate all desired output clk to DDR4 IP
3. Ensure the pll_locked and interface_locked is high. Data transfer should start after the assertion of this signal.
Aida
Hi Aida ,
Thank you for your reply ,
- we are sure that the reset_n is at 1 , we checked it on signal tap.
Our interface clock frequency is 1200MHz , and we select 150MHz for the PLL reference frequency.
We measured the input clock frequency and we are sure that it is 150MHz.
And I measured the clock output frequency , it is exactly 1200MHz.
We used Arria 10 PHY Lite in our last project , I believe that we should have set the PHY Lite settings correctly.
Other than clock signal output , we already have the control , address , DQ , DQS signals correctly output ,
thus our next step is to control the timing , however we don't know why the waitrequest signal of the avalon bus is always high ,
and we failed to access the avalon bus information.
3. Yes , we checked the pll_locked as well , it is 1 after the reset_n goes high.
We are currently using a 50MHz clock on the avl_clk , according to the specification , maximum frequency of avl_clk allowed is 167MHz , is it right ?
Looking forward to hearing from you , please let us know the possible reasons of having the waitrequest signal tied high.
Thanks ,
Samson
