Seems that aocl (openCL ) can't recognize "__prefetching_load" attribute in aocl 19.2??
Hi inteler
Environment: centos 7.5
aocl verison: 19.2.0.57
1 error: implicit declaration of function '__prefetching_load' is invalid in OpenCL
2 probe_buf[b].vector[s].data[i] = __prefetching_load(&probe[p robe_in_addr++]);
from the error hint, it seems that the openCL can't recognize "__prefetching_load" , but it shows on "Intel FPGA SDK for openCL pro edition best practices guide 19.2", it can found similar usage! Dose it need any other compile command???
- MEIYAN_L_Intel
This is an uncommon issues, I need to check internally with this issues.
Can you try to compile the simple example code in Chapter 1.3 as link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl-best-practices-guide.pdf
- zjinf
HI Mylee
i run the chapter chapter 1.3 case ,still wrong:
aoc: Environment checks are completed successfully.
aoc: Cached files in /var/tmp/aocl/iot may be used to reduce compilation time
You are now compiling the full flow!!
aoc: Selected target board a10gx
aoc: Running OpenCL parser....
/home/iot/work_example/tmp/prefetch/test.cl:11:35: error: implicit declaration of function '__prefetching_load' is invalid in OpenCL
sum[k] += __prefetching_load(&a[j]);
- HRZ
I think the possibility to control the LSU type was added in v19.3 and is not [fully] supported in v19.2. Only the guide from v19.3 has the "Controlling the Load-Store Units" section. The example in Section 1.3 of the v19.2 guide is probably a documentation error that mistakenly introduces an unreleased feature.
- MEIYAN_L_Intel
I will need some time to check internally about this issue.
- MEIYAN_L_Intel
The __prefetching_load() builtin is only available for the OpenCL SDK version 19.3 onward. A simple work around for 19.2 would be to replace
with
sum[k] += a[j];
The old version of this code can be found here https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/archives/aocl-best-practices-guide-19-1.pdf in Chapter 1.3.
There is an documentation error in 19.2 version which use _prefetching_load which is wrong.
I had reported to the team about the documentation error as well.
