Dr_FPGA's avatar
Dr_FPGA
6 years ago
X2go timing out local host connection
Hi, I am following similar instructions as in this thread: https://community.intel.com/t5/Intel-High-Level-Design/X2GO-client-connection-failure-Socket-Disconnected/m-p/656069#M209 However in m...
  • Lawrence_L_Intel's avatar
    6 years ago
    Which compute node are attempting to run X2Go on? You can check X2Go status with systemctl status x2goserver. Did you run the tunneling command from your local (PC) terminal, not the login-2 node? X2go doesn't run on all nodes. Best of luck, if you are still stuck, send me a few times for a quick conference call.
    Cheers
    Larry
