MDavi68
6 years agoHost channels arria 10 pac [DevCloud]
Hi, I am interested in work with the Intel host pipes in Arria10 FPGA, that is available in the a10gx_hostpipe bsp. In the Intel DevCloud I only see the a10_pac, which does not have channels. Is it ...
Lawrence_L_Intel
6 years agoI'm curious what application you want to run on the Arria 10 GX board that the A10 PAC cannot support? We can investigate installing that board, but it could take a month or longer as we need another server blade - all are occupied with PAC boards.
Larry
Dr_FPGA
6 years agoWhy just not to add Software support for host pipes to Intel PAC card? This should be less than a month, it is just a software update!
Our application is confidential at the moment. However, the convenience of pumping data via host channels has advantage of having much less code than handling ping-pong buffers with events, etc. And we all for less code and conveniences, correct?
