Mickleman
4 years agoFailure to fit an Arria 10 design through insufficent LABs when no problem in reports
Hi
I have a design for a kernel intended for Arria 10. I can compile and successfully run the design with both 1 and 2 copies of the kernel. There are still plenty of resources available so I am ...
- 4 years ago
Hi
With insight from an Intel FPGA expert I have now solved this issue. The problem is that the reports are misreporting the percentage of MLABs that the design is using. The compiler error message is correctly indicating that I am asking for too many MLABs whereas the corresponding Area Analysis report is saying I am using only 65% of them.
My solution is to check my MLAB use against the known MLAB capacity of the FPGA rather than trust the report.
Marcus
