Agilex 7 I-Series "aocl diagnose acl0" error following OFS
Based on the link provided, the changes is on the RAM 2x8GB interface. The PCIe should be still possible to be configured with 1x16 interface.
Apologies for the confusion. I've been trying to build the slim 1x16 PCIe using the following command:
./ofs-common/scripts/common/syn/build_top.sh -p --ofss tools/ofss_config/pcie/pcie_host_1pf_1vf.ofss iseries-dk:null_he_lb,null_he_hssi,null_he_mem,null_he_mem_tg,no_hssi work_iseries-dk_minimal_fim
But I've been running into a couple crashes and compilation issues after some time passes, notably an error stating: "Error: UNAVAILABLE: Network closed for unknown reason." This error has appeared several times at the same point in compilation, despite constant connection to my network via Ethernet cable. As such, I don't think it's a connectivity issue. Another user ran into this issue when compiling for an F-Series board (link), and their issue was resolved by upgrading system RAM to 96GB, so I am looking into possibly doing that as well.
My current system uses an i7-12700K and 64GB of DDR4 RAM. If you have any other insight or advice, please let me know as I continue to troubleshoot this new issue for the 1x16 PCIe configuration! The complete compilation log is attached for reference. I'll keep you posted if anything advances on my end.
Thank you!
James
- JohnT_Altera9 months ago
Can you try to implement the workaround in Why do I unexpectedly observe intermittent DDM Errors? | Altera Community - 349714?
- jjb1699 months ago
I had already implemented that patch before encountering these network errors, so that fix does not seem to apply to this case, thank you for the recommendation regardless! Any other suggestions would be greatly appreciated as I look towards potentially upgrading my system's RAM.
Best,
James
