Have you performed the build_asp.sh?
Can you also share the step you performed?
I just wanted to circle back and see if you had a chance to review my last reply with the Quartus project from the "bringup" folder, and see if it the correct one you requested, as well as see what you think may be causing my issues?
Thank you!
- JohnT_Altera4 months ago
From the design, it looks good. May I know which exact OPN of the board that you are using? Have you tested with non-oneAPI AFU design to test if your FIM and AFU is working?
Can you also provide the command and script that you use to performed the full compilation?
Have you try 2025.1-1 release version?
- jjb1694 months ago
I have not tried that OFS release version, as the notes state that 2025.1-1 has not been validated for use with oneAPI and to instead use 2024.2-1. I could perhaps try installing that version as well, but am hesitant to due to the lack of validation.
Thank you for checking the Quartus design! The OPN for the device on my board is AGIB027R29A1E1VB, and for reference the board was purchased at mouser with this link: https://www.mouser.com/ProductDetail/Altera/DK-DEV-AGI027-RA?qs=Znm5pLBrcAL6FowUR8Vkgw%3D%3D. I did make sure to update the part number within the configuration scripts as well, per the instructions in the guide. I did not modify any pin out information, however, as the default device also used an R29A package, so I assume that is okay.
I did not yet try testing the FIM using an AFU developed in Quartus without oneAPI, but was going to look into that and basic reference designs next to validate functionality as you suggest.
The command that I used to compile the FIM is as follows:
./ofs-common/scripts/common/syn/build_top.sh -p --ofss tools/ofss_config/pcie/pcie_host_2link_1pf_1vf.ofss iseries-dk:null_he_lb,null_he_hssi,null_he_mem,null_he_mem_tg,no_hssi work_iseries-dk_minimal_fim
I followed the steps in the minimal FIM part of the OFS guide (https://ofs.github.io/ofs-2024.2-1/hw/iseries_devkit/dev_guides/fim_dev/ug_ofs_iseries_dk_fim_dev/#45-minimal-fim) to create a PCIe 2x8 1PF/1VF Minimal FIM.
I look forward to hearing from you!
James
Can you try the PCIe 1x16 design rather than 2x8?
I initially tried to build a 1x16 design, but ran into the SystemVerilog errors which are shown in the text file attached to this response. This issue was also discussed in a similar forum post (link). Building a 2x8 configuration design avoided these errors, which is why I've been using that style so far.
Let me know what you think, or if there is a specific compilation script you would like me to run that may help solve these errors.
Thank you!
James
Based on the link provided, the changes is on the RAM 2x8GB interface. The PCIe should be still possible to be configured with 1x16 interface.
Apologies for the confusion. I've been trying to build the slim 1x16 PCIe using the following command:
./ofs-common/scripts/common/syn/build_top.sh -p --ofss tools/ofss_config/pcie/pcie_host_1pf_1vf.ofss iseries-dk:null_he_lb,null_he_hssi,null_he_mem,null_he_mem_tg,no_hssi work_iseries-dk_minimal_fim
But I've been running into a couple crashes and compilation issues after some time passes, notably an error stating: "Error: UNAVAILABLE: Network closed for unknown reason." This error has appeared several times at the same point in compilation, despite constant connection to my network via Ethernet cable. As such, I don't think it's a connectivity issue. Another user ran into this issue when compiling for an F-Series board (link), and their issue was resolved by upgrading system RAM to 96GB, so I am looking into possibly doing that as well.
My current system uses an i7-12700K and 64GB of DDR4 RAM. If you have any other insight or advice, please let me know as I continue to troubleshoot this new issue for the 1x16 PCIe configuration! The complete compilation log is attached for reference. I'll keep you posted if anything advances on my end.
Thank you!
James
Can you try to implement the workaround in Why do I unexpectedly observe intermittent DDM Errors? | Altera Community - 349714?
- jjb1693 months ago
I had already implemented that patch before encountering these network errors, so that fix does not seem to apply to this case, thank you for the recommendation regardless! Any other suggestions would be greatly appreciated as I look towards potentially upgrading my system's RAM.
Best,
James
