Advice on CNN inference on Agilex 7 using oneAPI
The "Report has invalid data. Ok to proceed?" error is unrelated to the bandwidth notes you are seeing; this is a known defect in the reports that you may ignore.
The incorrect Global Memory Bandwidth estimates might be an issue with your BSP; does the board_spec.xml that you got from Terasic have any value specified for Global Memory Bandwidth?
I think so. /vol/opt/intelFPGA_pro/21.2/hld/board/de10_agilex/hardware/B2E2_8GBx4/board_spec.xml contains:
<!-- DDR4-2666 --> <global_mem name="DDR" max_bandwidth="85312" interleaved_bytes="1024" config_addr="0x018"> <interface name="board" port="kernel_mem0" type="slave" width="512" maxburst="16" address="0x00000000" size="0x200000000" latency="240" waitrequest_allowance="6"/> <interface name="board" port="kernel_mem1" type="slave" width="512" maxburst="16" address="0x200000000" size="0x200000000" latency="240" waitrequest_allowance="6"/> <interface name="board" port="kernel_mem2" type="slave" width="512" maxburst="16" address="0x400000000" size="0x200000000" latency="240" waitrequest_allowance="6"/> <interface name="board" port="kernel_mem3" type="slave" width="512" maxburst="16" address="0x600000000" size="0x200000000" latency="240" waitrequest_allowance="6"/> </global_mem>
Moreover, if I compile an equivalent OpenCL kernel (aoc -bsp-flow=flat -rtl vector_add.cl) global memory bandwidth is estimated correctly (see screenshot).
- whitepau_altera1 year ago
Contributor
Thanks Bjorne; I'll forward this to engineering, you may have found a report bug.
- Björne21 year ago
Hello again. I might have solved my problem. Apparently the -Xstarget option should name a specific board and not an FPGA family.
So with -Xstarget=B2E2_8GBx4 the generated report looks much better. When synthesis is done in a few hours I'll check if I can run the generated bitstream on the FPGA. - Feng-Y-281 year ago
Hi Bjorne
May I get your environment set for DE10_Agilex?
My issue was stuck for half a month without process.
Could you give me the following enviro information, which can run the generated bitstream on the FPGA:- oneAPI DPC++ base toolkit version
- Quartus Prime version
I tried the 24.2 and 24.1 base toolkits, but all failed.
Feng
