oneAPI FPGA hardware error
When I tried to run oneAPI samples on devcloud, it shows error below, but I can run them before. I didn't make any changes.
quartus_sh: error while loading shared libraries: libncurses.so.5: cannot open shared object file: No such file or directory
Error: The patches required to compile for the target board (0.05dcp) is not installed for the following Quartus:
/glob/development-tools/versions/oneapi/2021.3/inteloneapi/intelfpgadpcpp/2021.3.0/QuartusPrimePro/19.2/quartus/bin/quartus_sh
dpcpp: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
make: *** [Makefile.fpga:30: vector-add-buffers.fpga] Error 1
- kkvasan
Hi @JInxuanBen
i am getting exact same error. were you able to fix this?
Many thanks
Vasan - BoonBengT_Altera
Moderator
Hi @JInxuanBen,
A response from the our platform team those broken dependencies are being reposition.
Hence while checking on the nodes, please do try to rebuild the design.And if issues persist, it would be a great help if you are able to provide the node# and also the run_fpga_hw.sh.
Hope to hear from you soon.Best Wishes
BB- JInxuanBen
The nodes are "u80211@s001-n018".
The issuse still persist.
It's a sample in github,vecter-add. I don't change any code.
build_fpga_hw.sh
#!/bin/bash
source /opt/intel/inteloneapi/setvars.sh
make hw -f Makefile.fpgarun_fpga_hw.sh
#!/bin/bash
make run_hw -f Makefile.fpga- JInxuanBen
build_fpga_hw_sh.sh.e952850
/glob/development-tools/versions/oneapi/2021.3/inteloneapi/intelfpgadpcpp/2021.3.0/QuartusPrimePro/19.2/quartus/bin/quartus_shdpcpp: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
- BoonBengT_Altera
Moderator
Hi @JInxuanBen,
Possible to share what are the nodes that you run to command on so that I can get the platform team to check on it?
Node# can be found when you are connected as below:
Best Wishes
BB - BoonBengT_Altera
Moderator
Hi @JInxuanBen,
Thank you for posting in Intel community forum and hope all is well.
We do receive some feedback that the hardware might be having issues, allow me to check this with the platform team.Mind if I asked in which node in devcloud that you are having this issues?
And also the which command/compile steps that the error are failing at?
BB- JInxuanBen
Everytime I try "qsub -l nodes=1:fpga_runtime:arria10:ppn=2 -d . run_fpga_hw.sh" or make hardware
the error below will show.
make: *** [Makefile.fpga:30: vector-add-buffers.fpga] Error 1- JInxuanBen
And I tried to find the file 'libncurses.so.5'. This file doesn't exist. I only found 'libncurses.so.6'.
