lkljucaric
5 years agooneAPI FPGA Compile Node Errors
I am currently experiencing errors when trying to compile FPGA designs using oneAPI. The errors I'm seeing:
Error: Compiler Error, not able to generate hardware
llvm-foreach: dpcpp: error:...
- 4 years ago
Hi @lkljucaric
I had the same problem which was resolved as follows on advice from Intel.
In the build script add a line at the beginning to ensure that the correct version of Python is used - here is the script I am now using:
#!/bin/bash
export PATH=/glob/intel-python/python2/bin/:${PATH}
source /opt/intel/inteloneapi/setvars.sh > /dev/null 2>&1
make hw -f Makefile.fpgaHope this works for you as well.
Kind regards
Marcus
BoonBengT_Altera
Moderator
4 years agoHi @lkljucaric,
Appreciate the details explanation on the situation.
It would seems there might be some node failure and platform inconsistency.
Apologies for the inconvenient, allow us to look into the mention node and will get back to you.
Thank you for your patients.
Best Wishes
BB
