OneAPI FPGA C Math Function Support
- 6 years ago
The reason of the error is you will need cl::sycl::exp()
oneAPI FPGA example designs that use math functions, for example the CCR example can be found here: https://gitlab.devtools.intel.com/ecosystem-dev-programs/oneapi-toolkits/oneapi-toolkit/-/blob/2021.1-beta08-ci/FPGAExampleDesigns/crr/src/main.cpp#L458
We will improve this documentation in https://software.intel.com/content/www/us/en/develop/documentation/oneapi-fpga-optimization-guide/top.html as user do searching in there.
You can refer to https://www.oneapi.com/ -> https://spec.oneapi.com/versions/latest/elements/oneMKL/source/domains/vm/sqrt.html?highlight=sqrt
If you had follow the syntax and still see the problem. Attached the files and steps for us for duplication.
