OFS : Data Path of QSFP from HE_HSSI
I do not have issue on clearing the HSSI STAT from my side.
Below is my logging.
pggae@pggae-PowerEdge-R740:~$ sudo hssistats
Namespace(pcie_address=None, clear=False)
sbdf: 0000:d8:00.0
FPGA dev: {'segment': 0, 'bus': 216, 'dev': 0, 'func': 0, 'path': '/sys/class/fpga_region/region0', 'pcie_address': '0000:d8:00.0'}
args.hssi_grps[('dfl_dev.3', ['/sys/bus/pci/devices/0000:d8:00.0/fpga_region/region0/dfl-fme.0/dfl_dev.3/uio/uio0'], '0000:d8:00.0', 21)]
fpga uio dev:dfl_dev.3
--------HSSI INFO START-------
DFH :0x3000000010002015
HSSI ID :0x15
DFHv :0.5
guidl :0x99a078ad18418b9d
guidh :0x4118a7cbd9db4a9b
HSSI version :1.0
Firmware Version :1
HSSI num ports :2
Port0 :100GCAUI-4
Port4 :100GCAUI-4
--------HSSI INFO END-------
HSSI num ports: 2
HSSI Ports | port:0| port:4|
tx_packets | 102| 0|
rx_packets | 0| 102|
rx_crc_errors | 0| 0|
rx_align_errors | 0| 0|
tx_payload_bytes | 7646| 0|
rx_payload_bytes | 0| 7646|
tx_pause | 0| 0|
rx_pause | 0| 0|
rx_errors | 0| 0|
tx_errors | 0| 0|
rx_unicast | 0| 102|
rx_multicast | 0| 0|
rx_broadcast | 0| 0|
tx_discards | 0| 0|
tx_unicast | 102| 0|
tx_multicast | 0| 0|
tx_broadcast | 0| 0|
ether_drops | 0| 0|
rx_total_bytes | 0| 7826|
rx_total_packets | 0| 102|
rx_undersize | 0| 0|
rx_oversize | 0| 92|
rx_64_bytes | 0| 1|
rx_65_127_bytes | 0| 1|
rx_128_255_bytes | 0| 1|
rx_256_511_bytes | 0| 0|
rx_512_1023_bytes | 0| 3|
rx_1024_1518_bytes | 0| 4|
rx_gte_1519_bytes | 0| 0|
rx_jabbers | 0| 0|
rx_runts | 0| 0|
pggae@pggae-PowerEdge-R740:~$ sudo hssistats clear
usage: hssistats [-h] [--pcie-address PCIE_ADDRESS] [--clear]
hssistats: error: unrecognized arguments: clear
pggae@pggae-PowerEdge-R740:~$ sudo hssistats --clear
Namespace(pcie_address=None, clear=True)
sbdf: 0000:d8:00.0
HSSI ID :0x15
DFHv :0.5
HSSI version :1.0
Firmware Version :1
HSSI num ports :2
Port0 :100GCAUI-4
Port4 :100GCAUI-4
HSSI num ports: 2
HSSI stats clearing ...
HSSI stats cleared
sbdf: 0000:d8:00.0
HSSI ID :0x15
DFHv :0.5
HSSI version :1.0
Firmware Version :1
HSSI num ports :2
Port0 :100GCAUI-4
Port4 :100GCAUI-4
HSSI num ports: 2
tx_packets | 0| 0|
rx_packets | 0| 0|
tx_payload_bytes | 0| 0|
rx_payload_bytes | 0| 0|
tx_pause | 0| 0|
rx_pause | 0| 0|
rx_errors | 0| 0|
tx_errors | 0| 0|
rx_unicast | 0| 0|
tx_discards | 0| 0|
tx_unicast | 0| 0|
ether_drops | 0| 0|
rx_total_bytes | 0| 0|
rx_total_packets | 0| 0|
rx_oversize | 0| 0|
rx_64_bytes | 0| 0|
rx_65_127_bytes | 0| 0|
rx_128_255_bytes | 0| 0|
rx_512_1023_bytes | 0| 0|
rx_1024_1518_bytes | 0| 0|
rx_jabbers | 0| 0|
rx_runts | 0| 0|
