fresher
1 year agoNetwork Workloads in N6001
Hi Team, I am using Intel N6001 SmartNIC, I have tested OFS design, and works accordingly as in documentation. How can I add network offloads such tcp offload using OFS design ? Is it possible to ...
JohnT_Altera
1 year agoHi,
I would expect that you are using OFS platform then yes, you may OneAPI (https://ofs.github.io/ofs-2024.3-1/hw/common/user_guides/oneapi_asp/ug_oneapi_asp/). If you would like to use RTL to implement AFU then you may refer to https://ofs.github.io/ofs-2024.3-1/hw/common/user_guides/afu_dev/ug_dev_afu_ofs_agx7_pcie_attach/ug_dev_afu_ofs_agx7_pcie_attach/.
