N6000/PL-1 SmartNIC image deployment error
Hi Kian,
Regarding OFS version, I did not use an OFS installer script. I compiled the kernel using this branch of the linux-dfl project:
git clone https://github.com/OPAE/linux-dfl.git -b fpga-ofs-dev-5.15-lts
Quartus version is Version 22.1.0 Build 174 03/30/2022 SC Pro Edition.
My knowledge of Quartus (and low-level FPGA programming) being limited, I'm afraid I won't be able to program the card using Quartus unless a ready-to-use project is available.
Frederic
Hi Frederic,
Sorry for the delay in replying, trying to setup a server on my end to test out the configuration on my side.
Do you mind to provide the file that you tried to flash in via this command "fpgasupdate --log-level debug ofs_top_page1_pacsign_user1.bin 0000:C5:00.0" ?
I will try it on my end and see whether I could see the same thing
Kian
- Dang_Tran__Frederic2 years ago
Hi Kian,
Please find the image as attachement.
Frederic
- KianHinT_altera2 years ago
Hi Frederic ,
I've setup similar system running the same OPAE and DFL with yours, and tried the fpgasupdate command . I could see the same error as you so I will debug this on my end.
The error is not related to bin file you provided, used the release bin also similar result.
Does upgrading the OFS version for both OPAE & DFL possible for you? If yes, let me try out the new version first.
Kian
Hi Kian,
Upgrading OPAE & DFL version is not possible because I need to stick to versions compatible with the P4 toolchain.
Actually, the linux-dfl version I've used so far (5.15.92-dfl) has a minor revision (92) more recent than the revision I was advised to use.In doubt, I downgraded the kernel to 5.15.45-dfl, reinstalled OPAE 2.1.1 and ... the problem goes away ! fpgasupdate completes successfully.
Frederic
