N6000/PL-1 SmartNIC image deployment error
Hi Frederic,
Sorry for the delay in replying to your post. Just a few questions
1) Does the fpga card working (eg running afu test or your program) after your see the error and done all the commands that you listed (lspci, fpgainfo fme)?
2) Did you do any prior flashing on the FPGA card before rebooting?
3) Does the issue happen 1 time only or every reboot also you see the issue "PCIe error recovery has occurred in slot number 1. The adapter may not work correctly."
It might be due to this intel-m10bmc-sec-update n6000bmc-sec-update.3.auto: SDM trigger failure: 4
If flashing SDM firmware , what I saw in our engineering database is that :
SDM provision firmware downloading requires Power Cycle, (This is SDM requirement).
Once SDM provisioning firmware download and key provisioning is done then we need to do power cycle.
Kian
