Beginner_in_FPGA
Contributor
2 years agoN6000-PL is not showing up in 'lspci'
Hey, I have with me the N6000-PL card which was provided by Intel. And am trying to test the card as is by connecting to a Dell PowerEdge R520 Server. This server is populated by a single CPU hence...
KianHinT_altera
2 years agoHi ,
I just did a quick check on my system running Ubuntu 22.04 , didn't get any AER errors when booting up. Probably need some setting there or ensure the card is programmed correctly.
If you require more time to test this since its not easy to keep switching OS just for testing, I would like to suggest to close this case first and once you tested on Ubuntu (with the pcie bitfurcation if you want as well), if the issue still persist , do submit another forum case or IPS case to us .
Kian
