MGRAV
6 years agon-bit intergers and memory broadcasting on FPGA using DPC++
Hi, I will start a new project of pattern search using FPGA. I need to have n-bit integer to store the pattern, and be able to broadcast the memory to do multiple pattern search in parallele with a...
SyafieqS
6 years agoHi,
Im not familiar with DPC++ but since you are using Quartus, I suggest you to use either VHDL or Verilog, assuming you want to use IPs from Quartus in your design, e.g Fifo for memory store your pattern ---> can be generate to HDL (VHDL/Verilog).
