MGRAV
6 years agon-bit intergers and memory broadcasting on FPGA using DPC++
I will start a new project of pattern search using FPGA.
I need to have n-bit integer to store the pattern, and be able to broadcast the memory to do multiple pattern search in parallele with a unique memory read access.
I wanted to know if it is possible to express this two operations using DPC++, or if I should go for VHDL or verlog langues ?
I asumed that is the best place to ask for this question related to the DPC++ syntaxe.
Thanks in adavance,
Mathieu
1 Reply
- SyafieqS
Im not familiar with DPC++ but since you are using Quartus, I suggest you to use either VHDL or Verilog, assuming you want to use IPs from Quartus in your design, e.g Fifo for memory store your pattern ---> can be generate to HDL (VHDL/Verilog).
