max 10 ethernet -remote update
hi
i m developing code for MAX 10 internal CFM memory update through Ethernet RPD file.
Q1.can you share me any utility to browse and send the file.?
Q2.from google i have got an 429 application software shall i use it for my update? (but it is not opening properly)
please respond ASAP
1 Reply
- JohnT_Altera
You may refer to https://www.intel.com/content/www/us/en/programmable/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/board-update-portal-based-on-nios-ii-processor-with-epcq.html for the reference design based on Cyclone V E with EPCQ and modify the design from AN741 (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an741.pdf) which provided you the guideline on the Max 10 remote update through UART. You can modify it so that you are using the Ethernet port to received the new image.
You may use it as reference or use the reference above.
