Issue with Compiling OFS Agilex PCIe Attach on F-Series Development Kit
Hi Raizz,
One more thing , instead of using this command alone " ./ofs-common/scripts/common/syn/build_top.sh fseries-dk work_fseries-dk ",
could you try this instead
./ofs-common/scripts/common/syn/build_top.sh --ofss tools/ofss_config/fseries-dk.ofss,tools/ofss_config/hssi/hssi_8x25_ftile.ofss fseries-dk:flat work_fseries-dk_flat
whether you still having the same issue
Kian
Hi Kian,
Thank you for your response, and I apologize for the delay.
I was successfully able to compile the design by increasing the RAM size to 96GB on my host PC. Additionally, there was a missing NIOS license file that I added after increasing the RAM. I have attached the log files for your reference.
Thanks and regards,
Raizz
- KianHinT_altera2 years ago
Hi Raizz,
Thanks for the update and glad that your FIM compilation now works. May I know whether does the RAM size increase alone able to solve the compilation, or need the Nios license as well . Just wondering about the root cause of that error message, as in the logs didnt seems to indicate any problems with Nios generation nor running out of memory.
Kian
