Issue with Compiling OFS Agilex PCIe Attach on F-Series Development Kit
Hi Raizz,
Just an update on my side, I've rebuild flat HE null again and the dk flat with no issues
i) ./ofs-common/scripts/common/syn/build_top.sh --ofss tools/ofss_config/fseries-dk.ofss fseries-dk:flat,null_he_lb,null_he_hssi,null_he_mem,null_he_mem_tg work_fseries-dk_flat
ii) ./ofs-common/scripts/common/syn/build_top.sh fseries-dk work_fseries-dk
I was searching our database to see any reported issues, so far didn't find any reported cases that relates to the issue directly except there is one case that has the same failure but it was trying to access example design stored remotely in server during testing. Also did not see any known issues with the release that related to this error
Error: generate_all_instances : INTERNALstill running after destroy
Error: UNAVAILABLE: Network closed for unknown reason
Could you check your Quartus license whether the license is activated (one brief comment was that the issue was due to licensing for access which i doubt in this case as you're building files locally)
May I know your kernel version as well (uname -a )?
I notice the "Info: mem_ss: Done "mem_ss" with 2 modules, 1 files" , on my side it should have more modules and files, not 1 file.
Attached is my build logs as well for reference
Kian
- Md_Raizz2 years ago
Hi Kian,
Thank you for your response, and I apologize for the delay.
I have checked that the license is activated in Quartus, and my kernel version is 6.1.41-dfl.
Please refer to the image below for your reference.Thanks and Regards,
Raizz
