Issue with Compiling OFS Agilex PCIe Attach on F-Series Development Kit
Hi Raizz,
Sorry it took some time to get the build working due to my system config but I manage to build the FIM successfully on dk flat HE null.
I didnt get any critical warning error on the file missing on my log side (though there is some warnings on some other non critical files)
First thing I noticed is that your Quartus is missing 2 patches which I suspect might be the cause of it since I'm comparing the logs between mine and yours and saw some process are missing.
log:
Do install the patches
https://github.com/OFS/ofs-agx7-pcie-attach/releases/tag/ofs-2024.2-1
You should get 0.02iofs , 0.18 and 0.26 patches when you check the version "quartus_sh --version"
Could you download and install those patches first and rerun the FIM generation?
Kian
- Md_Raizz2 years ago
Hi Kian,
Thanks for your update.
I completed the patch installation of IOFS based on your previous reply and have started the FIM generation. However, I'm still facing some errors during compilation. I’ve attached the logs for your reference.
In the meantime, I've kept fseries dk compilation again.
Thanks and Regards,
Raizz
