Issue with Compiling OFS Agilex PCIe Attach on F-Series Development Kit
Hi Raizz,
Sorry for the delay in replying, was setting up another server to duplicate via Centos to imitate Redhat environment, was EOL recently so had to reconfigure certain settings to build FIM again. Currently still in process of generating to try to duplicate the same issue.
Anyway on the log side, I saw dk-flat and he null dk-flat having the same issues, which is complaining on the files missing which is odd. It was not part of the github repository thus I'm assuming it should be generated out, had alot of critical warnings on file missing which eventually leads to error.
Whereas on the fseries-dk.log , seems like the process is killed early thus resulting in error
Let me try to duplicate on my side, and if able to I will escalate this to our OFS team to check what is the issue on the FIM generation.
Meanwhile i will continue to analyze to logs to see any other build issues.
Kian
- Md_Raizz2 years ago
Hi Kian,
I'm also debugging the issue on my end. Please keep me updated on any progress or findings from your side as well.Let's stay in touch as we work through this.
Raizz
